Hello Forum!
I am thinking of a build and I can't decide on RAM I want it to match the look and theme of this build: http://pcpartpicker.com/p/3zMTj (I will hopefully find a way to get a Be Quiet! dark rock 3 ore something of the sort) the theme as you can probably tell is red/black/clean. Also constructive criticism on the build would be appreciated.
https://linustechtips.com/topic/145280-need-help-with-ram/
http://pcpartpicker.com/part/corsair-memory-cmy8gx3m2a1600c9r
That is a very nice and balanced rig also, except for the HDD.
Or you're probably best off with Vengeance LP memory if you don't want to raise the 120mm fan on the cooler.
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1939994
Specs
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940003
The hdd is awkwardly expensive.. A 500GB hdd is usually less than $50.
The psu is pretty overkill. A decent 550w is already plenty.
How much ram are you shooting for?
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940017
Vengeance/Vengeance Pro in black, IMO. And just get a regular 1TB Barracuda. Waaaaayyyy better bang for the buck.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940025
I already own the500GB and I was shooting for about 8GBs.
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940057
Mushkin redline? if it's low enough, probably won't matter cus it'll be behind the cooler
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940059
Mark the item as 'purchased' in the future to not cause confusion.
Team Vulcan ram will easily fit: http://pcpartpicker.com/part/team-memory-tld38g1600hc9dc01
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940070
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($234.99 @ Amazon)
CPU Cooler:  Noctua NH-D14 65.0 CFM CPU Cooler  ($59.66 @ NCIX US)
Motherboard:  MSI Z87-G45 Gaming ATX LGA1150 Motherboard  ($149.99 @ NCIX US)
Memory:  G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  ($69.98 @ OutletPC)
Video Card:  EVGA GeForce GTX 780 3GB Superclocked ACX Video Card  ($509.99 @ Amazon)
Case:  Fractal Design Define R4 Blackout with Window ATX Mid Tower Case  ($119.99 @ Amazon)
Power Supply:  SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($79.99 @ Amazon)
Total: $1224.59
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-04-27 22:09 EDT-0400)
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940078
I'd also like the build to be quiet so if any improvement can be made there please tell. Me.
get an SSD. . . Haha serious. You'll get it so silent at some point even if not right away that your HDD will be the loudest component in your rig and it'll drive your mad (depending on how silent u wanna go)
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940079
hmm ok I guess I could add one. Any recommends?
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940084
samsung evo 840?
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940095
Also I don't know how silent that PSU is, but I have a Be Quiet one and I can tell you, that thing is silent
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940102
Recommended edits: http://pcpartpicker.com/p/3zO6p
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940107
IDE rather not go with the red team.
Why? The 780 is at least $50 more for similar performance.
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940169
I've had touble finding drivers with them and I have been to nvidias a driver site and it is amazing.
? AMD has a program that automatically finds the correct driver for you. http://support.amd.com/en-us/download/auto-detect-tool
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940210
Aren't bitcoin miners inflating the prices dor those?
In some places but prices are coming back down as you can see from the 290/780 price comparison.
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1940342
Hmm well Id'e still like to try an Nvidia card.
I'd advise to not needlessly overspend but it's your money.
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1943614
Does BeQuiet! have any single 12V rail PSUs?
https://linustechtips.com/topic/145280-need-help-with-ram/#findComment-1943785
