Hello Forum!
I am thinking of a build and I can't decide on RAM I want it to match the look and theme of this build: http://pcpartpicker.com/p/3zMTj (I will hopefully find a way to get a Be Quiet! dark rock 3 ore something of the sort) the theme as you can probably tell is red/black/clean. Also constructive criticism on the build would be appreciated.
go with gskill ripjaws http://pcpartpicker.com/part/gskill-memory-f312800cl9d8gbrl
I don't really like the way the heatspreader looks, I was going to go with some Corsair stuff: https://pcpartpicker.com/part/corsair-memory-cmy8gx3m2a1600c9r
they look great go for them just change the cpu cooler with corsair h60 and through the "corsair link" change the led to red to match your scheme and have a better cooling solution
I wanted to go with a BeQuiet! dark rock 3. (can I not download the Corsair Link software?)
the BeQuiet! dark rock 3 may interfere with high profile ram
i didn't understand ur question but the "corsair link" program is meant to control corsair cpu cooler that are connected with the mobo through usb
Oh I thought you were talking about the RAM LED (i'm not sure if there is one)
PcPartPicker says that the RAM and CPU cooler are compatible.
