I’m currently trying to build a PC for a my girlfriend as an anniversary present. I have everything I need except one screw. I am missing one of the screws that goes into and out the back of the motherboard with a washer. the motherboard is a b150 with an intel i5. If anyone knows where i can get more or buy ones that will fit, it would be much appreciated!
https://linustechtips.com/topic/1451755-please-help/
That looks like a standard-issue standoff. Screws are pretty standard. They're only there to keep the underside of the board from shorting out against the case. As previous poster stated, one screw missing shouldn't really hurt anything, as long as the standoff is there for support, but depending on location, without at least the standoff installed, just be sure to support the board wherever you're connecting things to it.
Edited by An0maly_76
Revised, more info
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1451755-please-help/#findComment-15540671
https://linustechtips.com/topic/1451755-please-help/#findComment-15540931
