http://uk.pcpartpicker.com/part/bitfenix-case-shinobiwindow
Really like the look of this case but i don't know whether or not it has them. In this build a guy did (http://uk.pcpartpicker.com/b/HPK) it shows that it does however i can't find out on Amazon.
Thnaks
https://linustechtips.com/topic/145147-does-this-case-have-front-panel-usb-3/
Yes, it does. The second link below Amazon from OverclockersUK showed usb 3.0 in the title and spec sheet.
According to the Bitfenix website it has two USB 3.0 ports: http://www.bitfenix.com/global/en/products/chassis/shinobi/
How big is the case? Is it as big as this, http://uk.pcpartpicker.com/part/fractal-design-case-fdcaarcr2blw
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
It is around the same size, yes
The Arc midi is a bit bigger than the Shinobi
Edit: The size of the cases are (WxHxD):
  • Shinobi: 204 X 459 x 489
  • Arc Midi R2: 230 X 460 x 515
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
