The stock cooler should be fine, but if you want better temperatures or a quieter system it wouldn't hurt to buy a better cooler. If you're unsure if you need it I would recommend trying the stock cooler and seeing if it works for you, and then deciding if you need to upgrade.
https://linustechtips.com/topic/1450114-about-cpu-cooler/#findComment-15529120
AMD coolers are serviceable but not great, and noisy, spending $30 for a basic aftermarket cooler on a new budget PC build that cost $700 to 1000$ seems a good investment to me
https://linustechtips.com/topic/1450114-about-cpu-cooler/#findComment-15529141
