Pc making a odd noise, Almost like a engine starting up
Sevva
I pretty much know nothing abt pc's besides to clean it out, But it making this sound like crackling or a engine stalling, I pretty sure it not the fans I can hear the fans just fine, Anyone know what's going and how I can fix it?
Do you have a wire/cable somewhere in the PC rubbing up against one of the fans? If not, then that's gotta be a terribly shot bearing, or the AIO having issues (if the AIO is, you should notice much higher temps than normal).
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
This thing almost never gets hot, Unless I'm playing a very high demanding game, I didn't build the thing, But I'll check if there's a wire up on one of the fan's
Yep, demanding games is where you'd notice it getting hot. Unless the hardware's getting into the 90s though, those wouldn't be worrisome temps. It's probably something in the fans then, I don't think bearings are that loud when they have issues.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
Alr thanks mans, I'll check that all out
2 minutes ago, _Omega_ said:
I guess the AiO is quite new, right?
I got the pc 27 days ago, July 16, Unless i got an older AiO, Then prolly
guess not, if it would have been an old one it might have been Air in the loop but with a new one it should be okay
Sounds like air in a pump if I where to take a guess or the impeller of the pump is rattling while it turns.
Get your ear close and find out!
