Download speed issue
Go to solution Solved by CreativeXtent,
I FIGURED IT OUT!!!!
The dang Killer Network Service for the drivers was limiting the connection....
I killed the service and BAM super speed again.
So i turned it back on and it limited it self. so i launched the app that controls it and somehow it was set to a max of 12.5MB/s down....
Howdy all. i am having a weird issue.
My speed on speedtest.net are what they are supposed to be 1400/40
https://www.speedtest.net/result/13501040793
But i can try to download any file from any website and i am making out at 1300kbs.
I was thinking maybe its just one of the sites, so i started downloading from different websites and it would split the speed between them all...
any idea?
https://linustechtips.com/topic/1447664-download-speed-issue/
update on this: it is something on my computer, not sure what.
I switched all cables, ports, router ports etc. i tried to download the same files on my phone on the wifi and its blazing.
But using the wifi on my computer it is still limited.
Metering is not turned on either...
https://linustechtips.com/topic/1447664-download-speed-issue/#findComment-15511337
any idea?
specs?
CPU Ryzen 5900X - Motherboard Asus ROG STRIX X570-E - RAM 16GB of G.SKILL NEON 3600 -
GPU EVGA RTX 3080 XC3 - Case Mastercase H500p mesh - PSU Seasonic Focus Gx-850 -
Corsair MP600 NVME 1 Tb, Samsung 960 PRO 500 Gb & 2 Seagate Baracuda 7200 RPM 2TB in stripe -
Display two VG27AQ 2K monitor - Cooling Corsair H150 Pro -
Keyboard G-910 W/ Romer G tactile - Mouse G 502 Hero (wired) -
Sound Logitech X-530 and Razer Tiamat headphones
Operating System Windows 10
https://linustechtips.com/topic/1447664-download-speed-issue/#findComment-15511370
38 minutes ago, CreativeXtent said:
1300kbs
did you mean Mbps? or are you really getting 0.1% of your expected download speed?
Assuming you're only missing 100M, check your CPU usage while downloading. Also try running sfc /scannow from an elevated CMD window and reinstalling drivers on your network card.
Finally, sometimes you just get small performance dips. Dropping 8% of speed is a bit annoying, but it's not a disaster. You might try hooking a fan to the side of the modem and router because they tend to be passively cooled and can overheat. If nothing else works you can always reinstall OS.
https://linustechtips.com/topic/1447664-download-speed-issue/#findComment-15511384
Nope i meant kb/s lol. that good ol 0.1%
Ran sfc and there were no issues. 😕
watching cpu while downloading, its at 8% with my other apps also running.
https://linustechtips.com/topic/1447664-download-speed-issue/#findComment-15511404
forgot to mention removed all drivers, reinstalled them. still a no go 😕
I checked the modem/router and its nice and cool.
My wife runs attached to that as well  Modem/router  - > Plume Wifi - > everything in the house except my gaming PC lol.
the wifi is fine on all devices except this PC also.
same limit
https://linustechtips.com/topic/1447664-download-speed-issue/#findComment-15511416
that good ol 0.1%
0.0
Okay... THAT is bad. I assume you've tried windows network troubleshooting? Also of course you've rebooted.
https://linustechtips.com/topic/1447664-download-speed-issue/#findComment-15511419
5 minutes ago, CreativeXtent said:
System
  • CPU
    AMD 5950X
  • Motherboard
    MSI X570 GODLIKE
  • RAM
    128gb Corsair dominator plat 3600
  • GPU
    EVGA KINGPIN 3090
  • Case
    Lian Li 011 Dynamic ROG
  • Storage
    3Tb nvme
  • PSU
    EVGA 1200w plat
You patch Mobo bios and used proper LAN/WIFI  drivers ? (gotta ask)
You using WiFI or patchcord to connect ?
If you are on patchcord, have you tried the other rj-45 on the back IO?
https://linustechtips.com/topic/1447664-download-speed-issue/#findComment-15511421
same limit
How old is the router?
Is it WIFI 5 or 6 compatible?
https://linustechtips.com/topic/1447664-download-speed-issue/#findComment-15511427
Yep, updated bios, put on proper drivers.
I tried wifi and ethernet. Both are limited only on this computer
Yep using the ethernet on the back of my computer i tried the 1gb port and the 2.5gb port just incase
https://linustechtips.com/topic/1447664-download-speed-issue/#findComment-15511430
That's really weird. My next step would be to try on another network.
https://linustechtips.com/topic/1447664-download-speed-issue/#findComment-15511434
router is maybe 8 months old. the wifi is separate. it comes from my plumes i alpha and beta test. They are wifi5,6 compatible.
I can download the files at around the full speed i am supposed to get on the wifi on any other device ( phones, wifes laptop etc. ) just not my computer.
https://linustechtips.com/topic/1447664-download-speed-issue/#findComment-15511435
https://linustechtips.com/topic/1447664-download-speed-issue/#findComment-15511451
