Low CPU speed
Go to solution Solved by unclewebb,
@Wr3ncher_B0i
In the TPL window, check the MMIO Lock box. Clear the Disable Controls box. Check the Speed Shift box. Set Power Limit 4 to a value of 0.
That should help. Run a log file if you are still having problems.
Hello there is a problem with my cpu sometimes causes its speed to go below even 1.10GHZ
My system specs:
8 gigs of ram
intel uhd graphics card
nvidia mx130
my cpu is intel i5 10210U
My laptop model: ideapad 3-15IML05 Laptop - Type 81WB
i cant provide screenshots since this is not currently happening
https://linustechtips.com/topic/1447514-low-cpu-speed/
If the CPU isn't under any load, it downclocks automatically to save power and heat.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1447514-low-cpu-speed/#findComment-15510210
1 minute ago, Wr3ncher_B0i said:
It is doing this under load
Load such as?
What are the temps?
https://linustechtips.com/topic/1447514-low-cpu-speed/#findComment-15510306
2 hours ago, Wr3ncher_B0i said:
problem with my cpu
Post pictures of ThrottleStop 9.5 while your CPU is throttling. Include the Limit Reasons window to find out why your CPU is throttling. Turn the Log File option on so you have a record of any throttling issues. Attach pictures and a log to your next post.
Excessive throttling in Lenovo laptops is common. ThrottleStop can fix many of these issues when it is properly setup.
https://linustechtips.com/topic/1447514-low-cpu-speed/#findComment-15510378
https://linustechtips.com/topic/1447514-low-cpu-speed/#findComment-15511312
is this enough
https://linustechtips.com/topic/1447514-low-cpu-speed/#findComment-15511340
39 minutes ago, unclewebb said:
@Wr3ncher_B0i
Include pics of the FIVR and TPL windows so I can make some suggestions.
Your computer has a power limit throttling problem, likely first triggered by high temperatures. This much throttling is not necessary.
image.png.00bfbcddf2a7888f595a3f9c76ad94b3.pngimage.png.a619f74d788a9bfa5a93722ead2ed72c.png
https://linustechtips.com/topic/1447514-low-cpu-speed/#findComment-15511441
10 minutes ago, unclewebb said:
@Wr3ncher_B0i
thanks a lot man no throttling currently ill let you know if i have a problem about throttling
https://linustechtips.com/topic/1447514-low-cpu-speed/#findComment-15511623
16 hours ago, unclewebb said:
@Wr3ncher_B0i
I cant charge my laptop after i did this
https://linustechtips.com/topic/1447514-low-cpu-speed/#findComment-15512486
