Hey, I'll make it brief. I'm 19 and I've been a pretty online person for most of my life. I would say I'm more technologically literate than about 80% of people, but ignorant when it comes to more advanced stuff. Security has never been something I cared much about bc I never did anything of importance on my PC.
Fast forward I've started a successful business in the past year and I'm handling all of my bookkeeping, business records on my PC and regularly logging into all my financial institutions.
Because I have something to lose now, I've started worrying about my cybersecurity more. I already have differing passwords across all my vital logins and use 2 step every time it's available. Like I said before I've been online most of my life so I'm not falling for sketchy links or anything like that either.
Is there anything else I should or could be doing? I've heard the popular VPN's are scams, not sure if that's true or not. Looking for a little advice
CPU Ryzen 5 3600 -  GPU GeForce GTX 1060 3GB - MOTHERBOARD Asus B550 Plus - - HARD DRIVE WD Blue 1TB - MEMORY Corsair 16GB DDR4
https://linustechtips.com/topic/1446726-cybersecurity-advice/
Password manager is a big one. That allows you to have a unique password for every single login you have since you don’t need to remember your password anymore.
That + 2 step are big. After that, don’t open up ports on your router, don’t open PDF’s or word docs from unknown sources, and good luck.
https://linustechtips.com/topic/1446726-cybersecurity-advice/#findComment-15504206
8 minutes ago, TreesMadeOfTanks said:
Hej, pokrótce. Mam 19 lat i przez większość życia byłam ładną osobą online. Powiedziałbym, że jestem bardziej wykształcony technologicznie niż około 80% ludzi, ale ignorantem jeśli chodzi o bardziej zaawansowane rzeczy. Bezpieczeństwo nigdy nie było czymś, na czym bardzo mi zależało, ponieważ nigdy nie zrobiłem niczego ważnego na moim komputerze.
Szybko do przodu W zeszłym roku założyłem dobrze prosperującą firmę i zajmuję się całą moją księgowością, dokumentacją biznesową na moim komputerze i regularnie loguję się do wszystkich moich instytucji finansowych.
Ponieważ mam teraz coś do stracenia, zacząłem się bardziej martwić o swoje cyberbezpieczeństwo. Mam już różne hasła do wszystkich moich ważnych loginów i używam 2 kroków za każdym razem, gdy jest dostępny. Tak jak powiedziałem wcześniej, przez większość mojego życia byłem online, więc nie łapię się na szkicowe linki ani nic w tym stylu.
Czy jest coś jeszcze, co powinienem lub mógłbym robić? Słyszałem, że popularne VPN to oszustwa, nie jestem pewien, czy to prawda, czy nie. Szukasz małej rady
Popular VPNs you mean the free ones? They are not a scam but the free ones often have data leakage.
When you use a VPN, your ISP cannot see what pages you are accessing, but the provider that is giving you the VPN service can see it.
If someone wants to find you, he will even find you using a VPN. You can use the Tor or Proxy browser to hide more on the internet, but I haven't heard of companies using this.
What does your company do?
https://linustechtips.com/topic/1446726-cybersecurity-advice/#findComment-15504210
