1 minute ago, Eumel2 said:
Can i carefully shave off that bit
Before making any physical alterations make sure you're inserting very carefully.
Since the 8 pin is keyed to only plug in one way, make sure you're not plugging it in upside down.
Are you able to insert the two pin by itself on the side of the 8 pin connector?
Primary PC:
PSU tier list
How many watts do I need?
