Budget (including currency): ~1700-1900 USD(inflation funny)
Country:USA
Games, programs or workloads that it will be used for: med and sometimes heavy gaming and light video production / general powerhouse
Tryna to upgrade from a Acer Predator Helios 300 ( intel 6 core 8thgen GTX 1060 6GB) still pretty powerful with some throttlestop finesse  despite being 4 years old. Still a great little machine. Battery doesn't last long though(thank god the laptop can run w/o the battery 😉 )
PCpartpicker:
https://pcpartpicker.com/list/vBKfnt
The GPU is there as a place holder for the general price of the build
I plan on using the 2.5 SSD(2) as a raid for video editing and the big 3.5 chonkers for games.
Already got peripherals and display worked out.( I am an audio
main concern is would it be worth to buy extra cables(sata , fan control , etc) just in case
prob will go for buy everything all at once option once I have the funds. which should be in mid September.
I sorta know how to build computers but that is a different topic
https://linustechtips.com/topic/1446177-~1800-first-computer-build/
Country:USA
PCpartpicker:
Overkill cooler
AM4 no more upgrades
you've spent nearly $200 for 4TB HDD's. Why not spend the same on a single 14TB HDD then? Wait a minute even a single 4TB HDD goes for $60 tf is this $90 they're got you for.
Could optimize SSD's. Needless cost.
Don't pay for a full windows license. Reseller will get you one for $20 not $100
Would recommend making a build then, not now. In two months time prices will change, availability will change and new generation of CPU's and GPU's will be announced, if not already be close to release.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
Country:USA
PCpartpicker:
1000w power supply is way overpowered for you pc and a waste of money, I would suggest getting a lower wattage psu.
Best is to wait for September and ask again then. Prices are dropping, and from what I understand around that time new stuff is launching.
Also you don't need any extra cables. Everything comes with the motherboard, PSU, etc. Sometimes motherboards only come with 1, but all of mine came with 2 SATA cables.
