For the Network Controller I would install the realtek lan driver
The other two google the device hardware id  (right click > properties > details tab > from the property menu select hardware ids > google the first id) to identify what it is. From there you should be able to workout what driver is required.
Alternatively check optional updates in windows updates.
https://linustechtips.com/topic/1444977-driver-help/#findComment-15492719
