Dear reader,
I am having an issue with Windows Deployment Services where I add my install Image I captured using powershell and it will show no images found on the client side. I will then remove the image from WDS and it will fix the issue. I was wondering if it is an image issue or a server issue, and how would I go about fixing that. Thank you!
https://linustechtips.com/topic/1444780-wds-issue/
33 minutes ago, Noxitb said:
It sounds liek an image issue but it could be a server issue as it may not be setup properly
I'm sure the server is setup properly because it works with other images, unless if there are drivers that are specific to PXE. And as far as my image, I don't know if there is probably a Network driver I need for PXE.
https://linustechtips.com/topic/1444780-wds-issue/#findComment-15491285
