It all started when I tried to put r5 5600G inside. I’ve read some Forums and it said that the MoBo didn’t support it until F34 BIOS version. I’ve tried to Update BIOS, but the QFlash button didn’t come on.
So I tried puttin r5 2600 inside and it worked BUT it randomly shutdown while I was trying to update. Well now the Orange on left side near Where it says Aorus light doesn’t turn on (should be orange) after only flipping the PSU switch.
i have tried:
Clearing CMOS
different PSU
different RAM
different GPU
nothing works. Just sittin here and trying not to cry
MoBo: Aorus x570 pro (non wifi)
CPU: AMD r5 2600, r5 5600g
PSU: Be Quite 850W Platinum
GPU: ASUS RTX 3080 10gb
M2 3th Gen 1tb
since I bought this 2 years ago it has no warranty. Help, what should I do?
https://linustechtips.com/topic/1444408-aorus-x570-pro/
Did you try Q Flash BIOS update with latest BIOS ?
It doesnt even need a CPU nor RAM
https://linustechtips.com/topic/1444408-aorus-x570-pro/#findComment-15488693
how did you formate the usb- stick?
Gigabyte X570 Aorus Elite,  Ryzen 9 3900x, Dark Rock Pro 4, 16 GB Crucial Ballistix  RGB 3600 MHz CL16 RAM, RTX 3080 TI FE Watercooled, 6 Case Fans,  Fractal Design Meshify S2
You are awesome, stay safe and healthy.
https://linustechtips.com/topic/1444408-aorus-x570-pro/#findComment-15488725
