I've been meaning to get a ups for a while, but I just haven't had the money for it, and I think I'll be able to save up for it in a month or so. That being said, I've seen a few from APC and CyberPower that might be ok, but I've had both in the past ( of their cheaper models) die on me, and I was looking for other experiences with a higher end one before I make the purchase. I have an EVGA T2 1600W psu and I'd like to be able to have a UPS that could pull 100% of that in the future and still be covered by my UPS. I'd love to hear what you all think!
https://linustechtips.com/topic/1443930-need-a-ups/
died as in battery depleted? usually you can just replace the battery and it will work normally.
the lifetime of the battery is around 3-5 years.
https://linustechtips.com/topic/1443930-need-a-ups/#findComment-15485264
As in, if they were plugged into the walls, no power was output at any of the sockets. Looking back, I think they were just surge protectors and not a UPS.
https://linustechtips.com/topic/1443930-need-a-ups/#findComment-15486353
