Using other Modular SATA cables
You cannot mix modular cables from different power supplies. There's no standard for how the wires are arranged and it's pretty clear from your photo even just from the [missing] pins being in different places on the connector that they are not compatible. Using incompatible SATA power cables can kill anything you plug in to them, including hard drives. Does the HDD still work if you plug in the good cable or did you kill the drive by using the wrong cables?
16 minutes ago, Andrewxe said:Is there any way I can re-purpose these two to be usable in my PSU?
You could use a depinning tool to remove the wires and repin them to match what the compatible cable. Use a multimeter on continuity mode and use the original cable and a guide that shows you which pins on the SATA connector are what to map out where 12V, 5V, 3.3V and ground wires go on the PSU side then copy that when you repin the other cable.
It looks as if the shapes of the connectors are different between the two connectors so they might not physically fit in the power supply socket, depending what the socket hole shapes are. The top middle shape near the tab is square on the left cables and D shaped on the right cable so if it's a D hole on the power supply then you shouldn't be able to fit the connector in the PSU... But there is a chance that the PSU is just using a square hole anyway which would take both D and square shaped pins.
