So I got a new motherboard and bought new 970 nvme m.2 drives. And two slots work perfectly fine but one will not register a drive. They all state 2_3 and I have gone into the bios to set them to nvme but nothing works. I could really use some help as I have all my stuff split between three drives with one dedicated to the os and can't transfer anything to the new drives or have access to all my games without swapping drives.
https://linustechtips.com/topic/1443500-pc-not-showing-m2-drive/
You can tell us more information about your system?
What is the motherboard (make + model)?
What CPU (make + model)?
You have two Samsung 970 EVO SSDs?
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
M.2_1 the one directly above your CPU will not work you need 11th gen for it.
and for the Sata ones you see that those will be disabled if you use the other M.2 slots.
Hope it helped you
Gigabyte X570 Aorus Elite,  Ryzen 9 3900x, Dark Rock Pro 4, 16 GB Crucial Ballistix  RGB 3600 MHz CL16 RAM, RTX 3080 TI FE Watercooled, 6 Case Fans,  Fractal Design Meshify S2
You are awesome, stay safe and healthy.
Hope it helped you
That does. thank you. Was worried that I had a faulty m.2 slot.
