Budget (including currency): 700$
Country: USA
Games, programs or workloads that it will be used for: recording and playing minecraft latest versions
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  I need a monitor and I would like for it to have at least 1080p and preferably more then 60hz I also need a headset and a microphone, doesn't matter if the headset comes with a mic or if it is separate
https://linustechtips.com/topic/1443475-pc-build/
Monitor and headphones dramatically eat into your budget, have to downgrade spec by quite the margin. From 6600 underbudget to 6500XT and still being over budget. Even if you wait for new intel GPU for around $130 it'll be just under your budget.
Extreme sacrafices is $2 over budget. I can't even tell if the board's gonna work. You're gonna be reliant on FSR to get decent fps in games. There are cheaper headsets but I have no idea how they sound. I know my HyperX clouds are great, have lasted me 8 years and I doubt the Alpha is any different:
PCPartPicker Part List
CPU: Intel Core i3-10100F 3.6 GHz Quad-Core Processor  ($68.98 @ Amazon)
Motherboard: Gigabyte B460M DS3H Micro ATX LGA1200 Motherboard  ($99.89 @ Amazon)
Memory: Silicon Power XPOWER Gaming 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($48.97 @ Amazon)
Storage: Western Digital Blue SN570 500 GB M.2-2280 NVME Solid State Drive  ($44.99 @ Amazon)
Video Card: MSI Radeon RX 6400 4 GB AERO ITX Video Card  ($149.99 @ Amazon)
Case: Rosewill FBM-06 MicroATX Mini Tower Case  ($44.99 @ Newegg)
Power Supply: EVGA BR 600 W 80+ Bronze Certified ATX Power Supply  ($44.99 @ Amazon)
Monitor: Philips 242E1GSJ 23.8" 1920x1080 144 Hz Monitor  ($139.99 @ Amazon)
Headphones: HP HyperX Cloud Alpha  Headset  ($59.99 @ Amazon)
Total: $702.78
Generated by PCPartPicker 2022-07-16 18:02 EDT-0400
Tell us your existing parts, we could maybe try and reuse some of those to save costs.
Or you're gonna have to turn to the used market for all of your parts, except SSD maybe.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1443475-pc-build/#findComment-15483609
I have a dell inspiron 15 3505 laptop with I think a 3450g and igpu 8 gb ram (5gb usable) and a 221gb ssd. If we were to increase the price by 100$ would that make a difference and if so I can increase the budget to 800$
https://linustechtips.com/topic/1443475-pc-build/#findComment-15483653
Yea laptop parts won't really do.Could Could resuse you SSD af boot maybe, either way much valuable storage.
If you were to up your budget by $130 not $100, you could get something that I think is worthwhile:
https://linustechtips.com/topic/1443475-pc-build/#findComment-15484297
