Hello, my PC has problems, please help!
when I turn my PC on ( using gpu as graphics ), it POSTs with the beep pattern 4-2-3-3 (apparently this means extended block move, what do I do with that?) and my PC does not turn on. When I tried to switch to my cpu's integrated graphics, it turned on with no problems.
What do you think is the problem and how do you think I can solve it? Need help ASAP, Thanks!!
ps. I already tried;
-swapping ram sticks
-reseating everything
-clearing CMOS
- switching PSUs (they are not the problem anymore)
What I haven't tried yet
swapping out GPU ( since I dont have any spare ones)
I am using
NEC motherboard ms9666 ver.012
CPU: intel core i3 540
GPU: AMD radeon hd 7850
SSD: walram 120gb
PSU: Inplay GS250BK ( ik it's bad, but I already tried it out with another PSU and it doesn't seem to be the problem here)
other components are working and seems to have no issues at all
After trying everything out, I think I have narrowed the problem to either a motherboard-not reading my GPU properly problem or a GPU broken problem.
I also tried updating my GPU's drivers but I can't because the PC does not turn on if it's power is plugged (also POSTs with 4-2-3-3 pattern)
Please help!!
https://linustechtips.com/topic/1443400-gpu-problem/
Nice info, we need more info. What pc is this, model, specs etc. If this is a dell: https://www.dell.com/support/kbdoc/en-us/000124349/understanding-beep-codes-on-a-dell-desktop-pc
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1443400-gpu-problem/#findComment-15481708
Thanks for the reply, I am using
SSD: walram 120gb
https://linustechtips.com/topic/1443400-gpu-problem/#findComment-15481720
pls help me bcos I really need this gpu working ASAP
https://linustechtips.com/topic/1443400-gpu-problem/#findComment-15485228
Suggeted PSU is 300W for 7850. Does that PSU have a 6 pin connector and do you connect it?
2021 nye 6 pin han til 8 pin (6+2) mandlige express power udvidelse  kabel-gpu power kabel - Computer & Kontor / www.dedadur.dk
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1443400-gpu-problem/#findComment-15485422
It does not have a 6 pin but I bought adaptors for it. Please note that I already used this PSU for months on this PC. Pls do not worry about the PSU anymore for I am quite sure that it is not the problem anymore
https://linustechtips.com/topic/1443400-gpu-problem/#findComment-15485435
Alright I have no clue then
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1443400-gpu-problem/#findComment-15485440
