2 minutes ago, dap53 said:
i use an intel core i5 2500 and it stays at around 60-70°C while gaming.
is it too hot? should i change my fan settings to see if it helps?
its fine, using a stock cooler im guessing right?
Main:
  • CPU
    10700k 5ghz All core 47 ring ratio 1.275v
  • Motherboard
    MSI Z590 A Pro
  • RAM
    4x8 viper steel samsung bdie: 4200-17-17-30
  • GPU
    Gigabyte RTX 3080 Gaming Oc
  • Case
    O11 air mini
  • Storage
    970 Evo Plus 500gb OS, Sn550 1tb, 860 evo 500gb, 2tb MX500
  • PSU
    RM750x (2018)
  • Display(s)
    Acer Nitro vg272up, Kogan 24 1080 120hz
  • Cooling
    arctic 280aio, EK M.2 NVMe Heatsink on 970 evo plus
    Second:
    Cpu: i5-8400
    Cooling: ID-Cooling Frostflow 120x
    Ram: 2x8gb 2666 c16 hyperx fury, tuned the absolute balls out of it but def not stehble.
    Mobo: Asus Prime H310M-K
    Gpu: Igpu
    Case: Coolermaster MB311L
https://linustechtips.com/topic/1443383-help/#findComment-15481599
I agree - That's well within spec, esp if that's while gaming/under load as indicated.
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
https://linustechtips.com/topic/1443383-help/#findComment-15481602
Just now, dap53 said:
yes its the stock cooler
yup the temps are perfectly normal
Main:
  • CPU
  • Motherboard
    MSI Z590 A Pro
  • RAM
  • GPU
  • Case
    O11 air mini
  • Storage
  • PSU
    RM750x (2018)
  • Display(s)
  • Cooling
    Second:
    Cpu: i5-8400
    Gpu: Igpu
https://linustechtips.com/topic/1443383-help/#findComment-15481604
