Help me brothers
Go to solution Solved by MageTank,
56 minutes ago, FloRolf said:
No, SSD Raid is RAID with SSD's. Unless you have two or more you don't have RAID.
However replacing the existing SSD will obviously result in having to reinstall the OS.
I have never found any issues with mixing ram personally. Only, like you said, they will both perform at the speed of the slower stick. If money is a thing, try mixing first and if it doesn't work properly, get a second one.
Dell sometimes configures both their laptops and desktops as "RAID ready", meaning they are a single drive shipped with RAID enabled in the BIOS and Windows configured with a RAID controller driver, but not actually configured in a RAID with another drive.
1 hour ago, GodofwarUk999 said:
I want to upgrade my laptop. However it's confusing to me which frequency should I chose. The model of the laptop is: Dell E7270. In the bios it says: 2133. However i can't find ram 2133 anywhere. Only 2600hz are sold. Is it going to cause issues?
2nd question. This laptop works only with ssd raid. Normal ssds under ahci wouldn't boot. Are ssd raid special or they are the same hardware. Thx
You have two options when it comes to the drive. Throw a second SSD in and load the RAID driver into the boot.wim of your OS and proceed with the BIOS configured as it is now. The second option is to disable RAID, configure back to AHCI and reinstall the OS cleanly in AHCI with no RAID driver at all. Either option is suitable unless you actually want to configure a RAID.
Others have already correctly answered the RAM question so I'll leave it at that.
https://linustechtips.com/topic/1443218-help-me-brothers/
2133 is the base speed for DDR4.  All sticks will run at this speed, and anything over it is technically overclocking (Even xmp or DOCP) Should be able to grab two sticks of DDR4 ram of your choosing and drop them in there. Just be sure to replace both, and not just try to add another 8gb stick.
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480596
Can you explain the SSD Raid thing? Are there currently two or more SSD's in there? And are you trying to replace them or adding some more?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480604
What is the reason for replacing both. They are kinda expensive here
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480607
Dell E7270 has function in the bios. Ssd raid. It's like a newer version of ahci. Aside from that I don't know. I try to buy bigger ssd
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480609
Any time you replace ram, you want them to be a matched set, as having one higher quality than the other with only hinder it and make it perform at the lower specs, if at all. There is a much better chance of things "just working" when you go with a proper two piece set.
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480615
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480620
I think that's true only for the high end machines like i9. Which have ram protection modules and bit verification. In i5 6th gen. Not that much
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480622
Upgrading  a Dell laptop ?? Haha rather try to upgrade a Honda Civic to a sports car 🙂
I mean you won't gain much if ever you manage to upgrade something anyway
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480648
Upgrades for anything and everything.  Dell makes none of the components in that laptop, so what's the issue?
Btw, enjoy an upgraded Civic too 🙂
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480674
My (incomplete) memory overclocking guide:
Does memory speed impact gaming performance? Click here to find out!
On 1/2/2017 at 9:32 PM, MageTank said:
Sometimes, we all need a little inspiration.
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480712
What about the ram. Would 2 rams from different companies be in conflict?
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480722
It IS actually preferable to get similar sticks from one brand, but if the specs are the same then you should be fine.  Real world... most RAM works just fine.  Any cheap 2133 RAM will most likely be fine if you're worried about money.  Otherwise find out the brand and specs of the installed RAM and try to match it.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480725
The short answer is, possibly, but highly unlikely.
The long answer is; laptops such as yours will likely only operate at JEDEC defined speeds which all memory should be capable of. In desktop memory with loaded XMP overclocks this would be a concern as different memory IC's (integrated circuits) can cause instability if they require different secondary and tertiary timings for stability that would be trained incorrectly.
I would say the odds are in your favor when it comes to mixing laptop memory as their training algorithms are extremely loose by design and seldom ever deviate from JEDEC unless they are purpose built for gaming.
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480727
Haha, then it's easier to upgrade a Civic 🙂 !
Dell does worse than that, they make build voluntarily crappy, uncompatible and unupgradable parts and BIOS software
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480822
I actually enjoy Dell laptops a lot. They release bios updates even after 7 years. I updated my tpm from 1.2 to 2.0. without changing parts. Etc.
Their security is really good. Compared to Asus. Who doesn't even enable secure boot. And gives you bare bones bios.
I'm torrenting all the time with 0 worries of getting doxed.
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15480974
Huh then we don't share same beliefs I'm a follower of GN Steve! 😁
Never used a Dell machine, never switched on TPM, but had no issues torrenting or even eMuleing before that!!
https://linustechtips.com/topic/1443218-help-me-brothers/#findComment-15481049
