Budget (including currency): 500
Country: Canada
Games, programs or workloads that it will be used for:
How much would you pay for this system on the used market :
CPU: Core i5-6500 3.2GHZ
GPU: ASUS Nvidia GTX 1070 8GB Turbo
SSD1: Samsung 850 EVO 500GB
SSD2: Kingston 480GB RAM: 48GB
COOLER: be quiet! Pure Rock CPU Cooler
MB: GIGABYTE Z170X-GAMING 3 LGA 1151 Intel Z170
PSU: Corsair CX Series CX650M 650W CASE: Fractal Design Define R5 ATX Mid Tower
MONITOR: ASUS PB278Q 27in LCD 2560X1440
and is it worth it to upgrade from :
CPU : i7 4770K
GPU : RX480
RAM : 16GB DDR3
SSD : 120 GB
MB : GA-Z87-HD3
Cooler : something random
(Open to selling this on the used market)
Monitor : Generic 1080P LCD panel
https://linustechtips.com/topic/1443066-help-with-used-pc/
CPU : i7 4770K
GPU : RX480
RAM : 16GB DDR3
SSD : 120 GB
MB : GA-Z87-HD3
No, the 4770K is faster than the 6500 and the 1070 is only a bit faster than the RX 480. If you already have this PC, simply upgrade the graphics card to something like a GTX 1080. If you also need a power supply upgrade that would probably be well within the budget.
Edited by Fasauceome
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1443066-help-with-used-pc/#findComment-15479546
My system is having some hardware issues cause crashes. I was wondering if I should buy I5 6500 system for about $450-500 CAD.
https://linustechtips.com/topic/1443066-help-with-used-pc/#findComment-15479555
For $450 it's not bad, but make sure your system isn't having a simple problem with something like the SSD or power supply
Primary PC:
PSU tier list
https://linustechtips.com/topic/1443066-help-with-used-pc/#findComment-15479566
Also it might be easier just to buy a new budget build and sell some old stuff:
12100F ~CAD 120
2x8GB@3200 ~CAD 70
MOBO ~CAD 130-150
PSU if needed
SSD if needed
Gaming should be similar or better vs 4770k (as far as quick a ggl search go)
https://linustechtips.com/topic/1443066-help-with-used-pc/#findComment-15479578
