Final thoughts on my build?
1 minute ago, DespicableR said:Suggestion on boards? Is the聽B550M PRO-VDH WIFI a good option?
Good enough but you get the most value out of ryzen by buying used so look for a used b450/x470 instead but b550m pro vdh wifi is also decent
聽
2 minutes ago, DespicableR said:I've looked for ram but basically the difference in price between 3200 and 3400 is negligible.
If you want superior rams i suggest buying some 2666 bare pcb crucial rams with c9bjz (top 2666 bin rev e ic) or d9wsm (rev j) which should do 3800+ cl14 by just copying someones oc profile off the internet. Cuts cost and increases performance with minor headache that comes with oc but thats mostly allivieated by copying a profile off the internet especially when microns are very consistent ics (what works for someone likely will also work for you), they dont look good but real men prefer performance over aesthetics
