Hey, is it ok to clean your rig with a hair dryer instead of regular compressed air. I know I vaccine cleaner can build up static.
Thanks in advance!
Should be ok, as long as you don't leave the hot end touching anything for long. Maybe try a vacuum first, though? That way, dust is getting sucked away, not blowing into the air :P
https://linustechtips.com/topic/144249-some-advice-on-cleaning/#findComment-1926336
It would work but will lack blowy power, also use the cold setting! A vacuum is good too but beware of your more delicate components and static could be an issue.
You might be better off trying to get a can of compressed air it is a bit better in the long run and as long as you use short bursts of air combined with a bit of sense. it should last a long time. Another great tool is a small paintbrush, I usually try to not use synthetic ones and not too vigorous but to get into a fan and so on it is a lifesaver, make sure the bristles are held securely to the brush and not loose!
Star Citizen LTT Conglomerate Wants you! Join now!
UOLTT Basop | Misc Freelancer & Origin M50
Outside of a dog, a book is a man's best friend. Inside of a dog it's too dark to read.
-Groucho Marx
https://linustechtips.com/topic/144249-some-advice-on-cleaning/#findComment-1926398
i prefer compressed air for my personal cleaning, but a hairdryer will do i guess :P
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/144249-some-advice-on-cleaning/#findComment-1926452
