Hi,
I'm currently in the market for a new monitor mainly for productivity (home office) and I would like to get a 34" ultrawide monitor. High refresh rate is not necessarily a must have, but since it's only a small increase in price, I might as well get a 144 of 165 Hz monitor. I have set my eyes on the AOC AOC CU34G2X, which is a 165Hz VA panel.
I'm currently using an IPS screen, so VA monitors are completely new to me. According to my research the contrast of VA panels is generally much better than IPS, but comes with black smearing.
VA seems the better way to go since curved IPS screens are quite expensive and with this size I'd think that a curved display is much nicer than a completely flat one.
Since I will mainly use the monitor for productivity (think Word, Excel, Teams, web browsing,...) I was wondering whether or not this black smearing is an issue or not.
Thanks!
CPU: Core i5 4690k                                                   Motherboard: Gigabyte Z97M                     RAM: 16GB HyperX Fury Red
GPU: RX 580                                                             Storage: Sandisk Ultra II 240GB                  PSU: Seasonic M12II Evo 520W
Case: NZXT S340 red/black                                      Case lighting: NZXT Hue+                          Mouse: Logitech G502
Cooling: Cooler Master Hyper212 Evo                     Operating system: Windows 10 64-bit
https://linustechtips.com/topic/1442309-va-panel-for-office-work/
The smeering/ghosting on VA is for fast moving images, and even then you often need to be looking for it to really notice it. Unless you're working on some seriously hardcore, fast moving excel worksheets, you'll be absolutely fine.
For work that does not require color accuracy you need a monitor that has response time as fast as its refresh rate so that it doesn't smear the image, you need high resolution and you need something that doesn't emit a ton of blue light.
With that in mind, go watch some of Hardware Unboxed monitor reviews. That's all I can say. I prefer smaller displays with higher resolution.
Oh alright that's good news. Will this smearing occur when I'm for example scrolling on a website in dark mode and white text? If so, how bad will that be?
Curved screens aren't ideal for work, mine serves for gaming mostly but for work I'd rather get a flat one
VA is fine, Excel won't smear on screen lol
Oh forgot to mention that the monitor is 1440p, so I think I'm good there. Do you mean that I have to get 144 fps in order to fully utilize the monitor? I'm guessing that in Windows this won't be a problem.
I have actually already watched the Hardware Unboxed review of this monitor. He was quite positive but did not really mention the smearing.
Can you elaborate why curved isn't ideal for work?
Because it's numbers and words and it's a bit weird when they don't line up...
Especially for big Excel spreadsheets😁
Yeah I agree with @PDifolco
I use to have a curve monitor and it drove me crazy to see curved lines. It was especially weird when I was working in Lightroom.
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
You won't see it. It's something you really have to look for when playing fast paced games. You're not going to notice anything for web browsing or office work.
Though yeah, reiterating what others have said, curved isn't great for office use. In particular excel where there are consistent straight, horizontal lines. If you're sitting in the perfect position it will be fine, but if you sit back in your chair or shift position, all those lines will become curved due to the angle you're looking at them from.
I've worked on a curved monitor. 1800R is pretty much the most i'd go for.. and even that is quite a lot. better two flat 16:9 screens than 1 bigger massively curved screen.
It can absolutely happened. VA main weakenss isn't the speed per se, it's the speed between dark colour transition and scrolling white texts in dark mode or scrolling black icon is one area where that can happen more offen than not. It can be mitigated somewhat buy having a better overdrive setting but this tends to be a lot worse in a more budget option.
But it's generally not too bad, you'll learn to ignore it fairly quickly and it does come with a benefit of not having the IPS glow (which make colour pop out a lot more, with IPS looks like you're watching colour through somethin grey filter in comparison sometime)
What you should be aware though is that some of the more budget VA may have speed issue even in lighter colour, this mean you can see smearing or ghosting outside of dark mode as well, and that can be a lot more notiecable.
For productivity it is OK. Curved won't make you see line weird or text weird for aspect ratio 21:9 and above. Unless the screen is very bad quality, normally it won't impact. Current curved screen in market is not curved until it impact to the wording, line or even image. Off course I always seat straight towards monitor screen and this is the correct seating also. If you are a person love to put monitor on side or never seat straight, you should be more concern on another issue - viewing angle. Viewing angle in VA is bad and the screen will washout if you didn't view straight on it.
For excel, such wider screen is freaking awesome as it reduce scrolling left to right.
As for the black smearing is not an issue but if only the VA panel is not good quality then during scrolling the text will like dissappear if white font in black or dark background. I not sure how serious this AOC one, you probably can check from review or if possible check yourself from physical unit. For high quality VA panel, this issue is some how never exist or very minimal but it ain't cheap and similar price as high quality IPS.
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, SONOS ACE, Technics AZ80, Technics A800E, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods MAX, Apple AirPods Pro 2, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile, Tablet & Smart Watch: Google Pixel 9 Pro XL (Obsidian) Apple iPhone 15 Pro Max (Natural Titanium), Apple iPad Pro 11" 2024 M4 (Space Black), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
