I overclocked my fx-8320 with the following settings I'm wondering why my task manager tells me my cpu is always running at 4.17ghz rather than going up and down as I switch tasks.
A.I. Overclock tuner: Manual
CPU Ratio: 21
AMD Turbo core: disabled
Cpu bus freq: 200
PCIE: Auto
Memory frequency: 1600
CPU NB: 2200
HT Link speed: 2400
CPU spread spectrum: disabled
CPU +NB volt: Offset mode
offset sign: +
CPU offset voltage: 0.11875
In the advanced area
Cool n quiet: disabled
C1E: disabled
SVM: disabled
Core C6 state: Disabled
HPC *something*: Disabled
Apm: Auto
https://linustechtips.com/topic/143946-overclocking-cpu-usage-help/
there is your answer.
C1E: disabled
SVM: disabled
Apm: Auto
Uhh... so what do I do to those?
enable them (you can keep c1e and c6 disabled if it causes stability issues)
you wont notice any degradation(more voltage will be needed for same overclock) soon but it makes your cpu to run at highest clock and voltage you set at all the time
