Make and model? A new SSD should be getting well over 50mb read and writes. Sounds like it was slow from the get go.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1438600-ssd-running-slow/#findComment-15448371
When it downloads i see in  task manager well over 200mb/s and my internet is around 500mb/s but istill very slow downloads recently
https://linustechtips.com/topic/1438600-ssd-running-slow/#findComment-15448374
Then where were you getting the 50mb/s? In order to do a real test you need to use an actual smart status testing program like Crystaldiskinfo or Crystaldiskmark. They should be able to tell you if the drive is actual bad and what it's real time read and writes are.
https://linustechtips.com/topic/1438600-ssd-running-slow/#findComment-15448383
Yeah ok thanks!
https://linustechtips.com/topic/1438600-ssd-running-slow/#findComment-15448386
