First: Are you sure that the MSI 750 Ti does not require supplemental PCIe 6 pin power?
Second: Are you sure that the Lenovo K410 itself is working? My Lenovo K450 started failing to output graphics of any kind a bit over a year ago - iGPU or graphics card. Have you tried to use the graphics coming out of the motherboard?
https://linustechtips.com/topic/1437996-750-ti-not-working/#findComment-15444355
I am sure it does not require extra power and also it had a quadro fx 580 in there before and it worked, I also tried it in my system that has a confirmed good pcie slot
https://linustechtips.com/topic/1437996-750-ti-not-working/#findComment-15444411
