Make sure you provide the link also. It seems fine by a glance besides the mobo cpu combo. I really don't see a reason to go previous gen so going 12700f or 12600kf would be my recommendation if you want to oc. Otherwise the 12700f is a good cpu
Samsung ssds are usually overpriced so you can probably find a cheaper one. I don't see the reason of a 500 gig ssd so I'd just save that m.2 slot
1 hour ago, DGG11 said:
I'm wondering if I should go with 16gb or 32gb ram.  I feel like the rest of it looks pretty good but if you guys have any suggestions I'd love to hear them.
RAM is fairly cheap and easy to upgrade. If you don't need 32, go 16.
Depending on where you're buying, last gen can be a little cheaper and easier to find.
