Basic Computer for basic needs
In such price, it's nearly impossible for even getting a budget build if you want to get a new item (trust me, I tried) with a decent-enough performance. Best of what you can do is actually get secondhand items, and since the price's really vary in between places, best of what I can do is to suggest what's kind of close to my place's price. And, no. I don't think getting your components from USA with such budget, it would be absolutely ridiculous.
I assume you already got peripherals like monitor, mouse, and keyboard. So, here's below of what I could suggest.
CPU: any CPU that got the minimal of 4 cores, 4 threads, I could say this is mandatory for the sake of CSGO. I strongly go for Intel if you wanna pick items pre-Ryzen, perhaps I could suggest Haswell-era i5-4460 or Xeon E3-1230 v3.
Motherboard: depends on the CPU obviously. If you pick is between of the i5-4460 or Xeon E3-1230 v3, get the cheapest H81 motherboard you could find.
RAM: 8 GB for the absolute minimum, 16 GB is the optimal one. Just max the whether speed your CPU and motherboard supports.
GPU: get secondhand, could spend most of the budget on this as you actually game (I could suggest you a iGPU system but, trust me, you don't really want to because it feels really sucks). Something like R7 2xx series or GTX 950 would do the job fine.
PSU: please. Don't get cheap on this one. For real. Even in budget builds, PSU would be the first priority to get the quality ones, no matter how small your budget is. I saw enough amount of cheapo PSU killed my friend's components.
For PSU, you could visit the PSU tier list and perhaps take the Tier C MINIMUM, or just ask the forum on PSU thread, perhaps on 500W power as you'd use that GPU anyway. I personally took a bequiet! System Power 9 and it runs fine until now.
Case: just get the cheapest you could find, or even reuse your old ones.
Quick little research and you perhaps could go for this. This is on Indonesian marketplace price so yours may be really vary.
