Budget (including currency): 500
Country: U.S.
Games, programs or workloads that it will be used for: media center and 1080p light gaming
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc)
trying to reuse my old (sapphire hd 7970ghz toxic) in a pc to stream to the TV from and some light 1080p gaming for my gf.
already have ram and a spare ssd. but need a motherboard, cpu and power supply.
mostly need help though finding a small enough case that can sit on its side that will fit a large gpu.
Card Dimensions (L x H) 10.83" x 4.53" x 2.04"
https://linustechtips.com/topic/1437044-mostly-need-case-reccomendations/
I'd use mm instead because that's what almost every case manufacturer uses instead of inches. That's should be around ~275 mm so this is what I would do
https://pcpartpicker.com/list/Kz8Jk9
If you plan to use only really light games then Id go down to a 12100f and save yourself 60 bucks. You can probably find a cheaper case but this the only one I found after a light scroll on pcpart picker that meets your requirements.
