Budget (including currency): 250 USD
Country: USA
Games, programs or workloads that it will be used for: Zoom, Internet Browsing Word Processing
I'm not familiar with hardware in this price range. I don't know how one can even build a desktop within this price range. Can someone please lend me a hand? This is for someone that just wants to use the computer for nothing but using Zoom, surfing the internet, watching YouTube, and doing word processing. The person was using a newer laptop HP Laptop 14-dq005dx (https://support.hp.com/us-en/product/hp-14-d0000-laptop-pc-series/28803377/model/38322708/document/c07006533) and it had difficulty with Zoom. This person does not want to do any gaming. I assume an integrated graphics CPU would be required.
I believe that buck for buck, a desktop would outperform a laptop, but at a $250 price range I'm not so sure if that applies.
My friend can use her TV as a monitor, and then a mouse and keyboard combo for about $20 at goodwill.
Can someone help me put a build together for this budget.?
https://linustechtips.com/topic/1436054-help-building-a-budget-pc/
19 minutes ago, Yoshi Moshi said:
Yea I figured. A Dell Optiplex would be the best for 250$ budget?
That would be my guess at least. Something like this
https://www.ebay.com/itm/374120531497?hash=item571b524629:g:hEoAAOSwyA5ioTZt
Would probably be enough for zoom and browsing the web. Although you might be able to find a better config or for cheaper based on your location and local pcs
