This is about the way im sitting. This all may sound stupid but here I go.
I don't know what position to sit at on my desk while playing fps games. I feel like the current position im sitting in is heavily effecting my aim and im not sure how to be comfortable and if im sitting right.
My arm rests are under the desk. I would like the chairs arm rest to go a bit more back so i can sit closer to the desk and have my arms levelled to the desk but this chair doesn't do that. but im just confused all the way.
I have to lower my chair because the arms rest wont fit under the desk allowing me to go close
is my arm rests at a normal position?
What do i do??!?!
https://linustechtips.com/topic/1434015-i-need-some-help/
No, that looks really uncomfortable. The armrests should be desk height. But most of the gaming chairs are an ergonomic nightmare, but try to get to as close to ergonomic sitting position you can. If you feel like you need to be closer to the desk, try bringing the mouse and keyboard more towards the edge of the desk.
Ergonomic Practices for the Home Office - Women's Economic CouncilPin on Technology and Society
Ergonomics - Correct and incorrect sitting posture when using a computer  Stock Vector Image & Art - Alamy
I only see your reply if you @ me.
https://linustechtips.com/topic/1434015-i-need-some-help/#findComment-15415464
  Reveal hidden contents
@Origami CactusI have the secrete lab evo 2022. i wish the arms rest would go a bit more back. I've put the armrests at desk level. now i cant move around left and right as the arm rest is legit touching the desk.
https://linustechtips.com/topic/1434015-i-need-some-help/#findComment-15415478
Your baseline should be arms at desk height.
I do generally suggest very slightly tweaks (probably +/- 0.5-1" to chair height) about once a week though to add a bit more variety to the actual movements your make though.
5900XT (16C/32T) | 64 GB DDR4 RAM | RTX 5070
1.5TB Optane P4800X | 16TB nvme SSD NAS w/ 10Gbe & 96GB DDR5 RAM caching
LG C4 + QN90A | Sony AZ7000ES | Polk R200+R100, ELAC OW4.2, SVS PB12-NSD + 3x SB1000 | HD800
https://linustechtips.com/topic/1434015-i-need-some-help/#findComment-15415492
And? Don't understand how that is a problem. The arm rest should be touching the desk, and you shouldn't move around left and right, unless I am misinterpreting something in your sentence. Try to look at the drawings I included in my post.
https://linustechtips.com/topic/1434015-i-need-some-help/#findComment-15415524
Repetitive Strain Injury is real. Some day you'll be 40. Take care of your body, or you'll be in pain every day for the rest of your life.
I use a desk with a keyboard tray so that my wrists are not at an angle; they are parallel with the keyboard mouse surface. I also use an embody chair I picked up on craigslist for $400; this chair has adjustable arm rests. But really, you just need to adjust the height of the chair you have, so that your lower arms are pretty much parallel with the mouse the keyboard.
You can get a desk with a keyboard tray, but they're not as common now.
Money spent on saving yourself from carpal tunnel and tendonitis is money well spent.
https://linustechtips.com/topic/1434015-i-need-some-help/#findComment-15415631
My arms are quiet tiny and they dont seem to reach the mouse and keyboard properly, the arm rests come in the way. Dunno if that's just me though.
https://linustechtips.com/topic/1434015-i-need-some-help/#findComment-15415724
Remove the arm rests from your chair (or just lower them all the way) and move your keyboard and mouse further away from the edge of your desk. Use the desk as your arm rests.
Or, look at how the pads and arm rests on your chair are designed. If they're asymmetrical front to back, you might be able to flip the pads around so they stick further back than to the front. Then you can get your chair closer with the arm rest pads still level with the surface.
https://linustechtips.com/topic/1434015-i-need-some-help/#findComment-15416021
