Need help with Chrome
one is HTML the other Flash.
Flash can go over 1080p in YT but not HTML.
(I'm talking about the video player)
Yeah I figured that out moments after posting this, but it still wouldn't let me disable HTML 5 for chrome, I wasn't in the trial/beta but it used it anyway.Tried joining trial and leaving it like some users on Google groups suggested and nothing.
Finally found an answer on Google groups
Here's how I disabled HTML5 video in Chrome on Windows:
Find the file called ffmpegsumo.dll where Chrome is installed (C:\Program Files (x86)\Google\Chrome\Application\30.xxxxx\ for me).
Delete it or move it out of that folder.
And it forces chrome to play using flash.
*update*
@Jogostar brought up an easier solution.
install the Magic Action plugin from the chrome web-store and enable force player type, and under that choose flash.
*update*
When you delete the ffmpegsumo.dll file it forces flash in all scenarios, included embedded videos, Magic Actions however does not force flash player when videos are embedded, if this is important to you just delete the file.I deleted it and installed Magic Action because of some of the other nice features it provides.
