2 minutes ago, Volcomlancer said:
Can someone map out where the two cpu psu connectors go and the 3 pcie? It looks like a free for all or both cpu connectors on the left side
Top left 3 and bottom left 2 are CPU/PCIe. You can plug them in however you want, the PSU ends are the same with how asus has designed their cables on that PSU.
https://linustechtips.com/topic/1433744-help/#findComment-15413724
3 minutes ago, Volcomlancer said:
The amount of youtube videos i watched 😂😂 ty for the help
Whats nice is…. You literally can’t plug them in wrong. The cpu and PCIe are all 4 pin, and sata and molex are 3. So even if you tried, you can’t plug them in to the wrong place.
https://linustechtips.com/topic/1433744-help/#findComment-15413731
All of the 8-pin connectors are the same.  All of the 6-pin connectors are the same.
https://linustechtips.com/topic/1433744-help/#findComment-15413732
