18 minutes ago, dekibk2 said:
Its not.Im getting high temps in idle
I suspect that the temperature sensor is faulty.
And since it thinks you are going sub-zero it probably tells the fans to be at low RPM or zero RPM mode,
So your system will get hotter because the motherboard tells the fans to to less work than they should.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
