Hi I recently built my pc with a powercolor oc 6800 and its underperforming https://nz.pcpartpicker.com/product/qHfFf7/powercolor-radeon-rx-6800-16-gb-fighter-oc-video-card-axrx-6800-16gbd6-3dhoc
in apex when upscaled to 1440p from 1080p highest settings it only gets 120fps almost of the time and at native 1440p it gets 100 fps overclocked pls help ive seen other benchmarks with the same gpu and settings and they 170fps
https://linustechtips.com/topic/1432273-6800-underperforming/
What are the rest of your system specs?
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1432273-6800-underperforming/#findComment-15404028
Can you just download free version of 3dmark and run a benchmark and share your results? There is a reason why online games are rarely used for benchmarking, because they are so frequently updated and more content keeps added to the game so results are not coherent for benchmarking or any sort of apples to apples comparison.
https://linustechtips.com/topic/1432273-6800-underperforming/#findComment-15404033
Just now, Karlh975 v2 said:
12600k 16gb crucial balistiks 3600mhz cl 16 280mm water cooling
Alright, seems fine there. GPU temps OK? Is it running at PCIe 4.0 x16?
Works Cited
https://linustechtips.com/topic/1432273-6800-underperforming/#findComment-15404041
yes dosent go over 55c and is on pcie 5.0 although it dosent take advantage of it
Well is it actually running at x16 and set to that in the BIOS? Would you download GPU-Z and check?
Works Cited
https://linustechtips.com/topic/1432273-6800-underperforming/#findComment-15404049
yes its at x16
OK - then as was previously said, can you run some other benchmark, since games will perform quite differently on every system?
Works Cited
https://linustechtips.com/topic/1432273-6800-underperforming/#findComment-15404059
There are other and many factors that can affect the performance of the gpu in games. Like the following:
1. System Cooling
2. PSU capacity
3. Motherboard chipset and build
4. CPU
5. CPU and GPU overclocking settings
6. etc...
Try playing with your settings(optimal and overclocking). And do more benchmarks. And choose the highest and most stable profile. Then that will be your maximum's PC overall build quality performance.
https://linustechtips.com/topic/1432273-6800-underperforming/#findComment-15404143
39 minutes ago, Karlh975 v2 said:
Only judging by that benchmark, your cpu performs ~ the same as mine (same model). I dont know how the score is calculated, but your gpu score is  only ~16% higher than mine, but I only use a 1660 super. Running more benchmarks (3d mark timespy and more) seems like the best option. Then maybe someone with a 6800 can compare results.
https://linustechtips.com/topic/1432273-6800-underperforming/#findComment-15404147
