So I just finished my build with two 3x120x54mm rads and I’m running a 5950x and a strix 3090. On my cpu I see from mid 30s idle to 40s and running a game I see mid to high 70s on the cpu. My gpu stays in the 60s while gaming. I have a d5 pump in the distro block and I have it set to full speed but it seems to be moving slow. Is this to be expected ?
Project Casper - Glass Tubing Build
Ryzen 9 5905x     |    Gigabyte Aorus Extreme X570    |   Strix 3090
GSkill 64gb 4000mhz   |    EVGA 1600T psu     |      3x Samsung 980 Pro NVME 1tb Raid 0
  4 x Crucial MX500 2tb raid 0   |    Glass Hard Line Tubing  - EKWB Blocks
https://linustechtips.com/topic/1431357-cooling-question/
Sorry D5 pump set to full Speed?!? the D5 is an industrial pump and even with a high resistance loop e.g. 4 gpu blocks it only really needs to be set to about 50% at most. water that seemingly moves slow is normal. I would say your fans and their seal against the radiators is going to have a bigger impact on temps that your pump speed. I bought the Lian-Li SL120s and they do not seal against my rads at all and have virtually no static pressure so my temps are in the high 90s despite running 3 triple rads.
PC:
CPU: Ryzen 9 3900X @ 4.25GHz
RAM: 32GB Patriot Viper Steel 15-15-15-36 @ 3600MHz
Motherboard: Gigabyte Aorus Master X570
GPU: Powercolor RX 6800XT Liquid Devil
SSD: 500GB 970 Evo Plus, 500GB Pioneer NVMe, 480GB BX500 SATA.
PSU: Corsair AX1600i
Cooling: EKWB Watercooling
Case: O11 Dynamic XL + EKWB Reflection distro plate
Laptop: Framework Batch 10
I5-1135G7
24GB 2400MHz
500GB PM951
https://linustechtips.com/topic/1431357-cooling-question/#findComment-15397654
Normally I don’t run the pump that fast but when I first built the system I had issues getting the coolant to move up thru the loop (also made some strange noises, not my first d5 but the first time using a built in one in a distro) I have Corsair ML fans both pulling through the rads
https://linustechtips.com/topic/1431357-cooling-question/#findComment-15397655
I would say your temps seem fine so there shouldn't be any issues unless your flow indicators are spinning very slowly e.g. 4-5 seconds per rotation everything is probably fine. if you are running any blocks backwards it could explain lower flow rate however.
PC:
I5-1135G7
24GB 2400MHz
500GB PM951
https://linustechtips.com/topic/1431357-cooling-question/#findComment-15397661
do you have a pic? i no some distor plates were having problems with some d5 pumps but you think they fixed them by now.
Edited by thrasher_565
https://linustechtips.com/topic/1431357-cooling-question/#findComment-15397684
It’s an ek reflection block
https://linustechtips.com/topic/1431357-cooling-question/#findComment-15397693
I didn’t think about the backwards block. I had to run it backwards on the gpu…. Should I swap the flow on it ?
https://linustechtips.com/topic/1431357-cooling-question/#findComment-15397695
