UPS
23 hours ago, brob said:It's not a good idea to plug in a power strip. However I have safely used short multi outlet extensions. It's important that such extensions have no breaker or other protective circuitry.
If you scroll down https://www.apc.com/in/en/product/BX1100C-IN/apc-backups-1100va-230v-without-auto-shutdown-software-5-india-outlets-1-surge/ to Specifications you will see that you can enter a load and the page will calculate an approximate run time. An i5-12400 system with no discreet GPU will likely not draw more than 200W. In fact it probably would not go above 120W most of the time.
I’ll probably use 2 of these ups’ and have a surge protector between the ups and the wall to protect everything as only one outlets is surge protected assuming that they can sit between the wall and my decide and make sure power is not interrupted between it going out and the generator kicking in
