nop.
https://linustechtips.com/topic/142975-does-it-fit/#findComment-1908649
Apparently the 200R has a CPU cooler clearance of 160 mm (http://www.bit-tech.net/hardware/cases/2012/11/15/corsair-carbide-200r-review/1). The NH-D14 is 160 mm, so if it does fit, it would probably be quite snug...
sad story.
Equality doesn't mean Justice.
https://linustechtips.com/topic/142975-does-it-fit/#findComment-1908710
nop.
It will easily fit..
https://linustechtips.com/topic/142975-does-it-fit/#findComment-1929731
