WWAN modem card for an industrial tablet device thing
Solved by Falcon1986,
On 5/7/2022 at 6:45 AM, Meowster said:Will a branded card work with my tablet? Or do I need to find a non branded one, such as a Sierra one perhaps?
Have you tried searching online support forums to see what others have used? Since the manufacturer is no longer available, you'll have to rely on what others with similar devices have done. There's not much we can do to help if you don't share the exact make/model.
If the cards you've found are inexpensive, it might be worth it to just try one. Keep in mind that some OEMs will lock hardware support through the BIOS to specific brands.
