Cpu cooler compatibility
Go to solution Solved by jaslion,
The intel stock cooler doesn't have a bracket.
You need a bracket that is made for the specific cooler.
Just now, TheWolfBlade said:
ok, thank you
As @jaslion said, the stock cooler doesn't have a bracket, it just uses pushpins. There are a few aftermarket coolers that mount in the same way but they aren't necessarily ones you'd want to buy.
If you buy a cooler that doesn't come with the LGA1700 bracket, most of the major brands will send you one for cheap (maybe only the cost of shipping) if you contact them and show your proof of purchase.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
