Computer not going to sleep.
Go to solution Solved by Giantnoggin,
Ok nm I posted prematurely.  I found that my wavelink software was doing it.  So I uninstalled and reinstalled and it works like a charm now.
Hello i've found that my computer is not going into sleep mode.  After running powercfg -requests I can see that there are 2 items that appear to be keeping the pc awake. I am unclear how to track down these drivers and when I do how do i fix them?  I don't want to run the cmd that just tells powercfg to ignore them as that feels like a bandaid solution.  Unless it is the real solution.  Please help seems to have started about 3 days ago, never had this issue before.
SYSTEM:
[DRIVER] Realtek High Definition Audio (HDAUDIO\FUNC_01&VEN_10EC&DEV_1220&SUBSYS_10438735&REV_1001\4&287b1049&0&0001)
An audio stream is currently in use.
[DRIVER] Legacy Kernel Caller
https://linustechtips.com/topic/1428477-computer-not-going-to-sleep/
Good you have it fixed. 👍
For anyone else having this issue, i've found latest Logitech Gaming gear software to do the EXACT same.
Keep your device from entering sleep, turning off the mouse in question (G903 in my case) works. But also uninstalling the lousy software works.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
