python and selenium; failing to confirm if an xpath is present or not
12345678
basically in the website there might and might not be a box, so I wanted to make it check if that box does exist, and then if it exists run another piece of code.
to do that I got the xpath, since it looks like it has not an id or other sort of identification, but it doesn't work
https://pastebin.com/DMR20zBf
2 hours ago, shadow_ray said:
That snippet is not even syntactically correct. And FindElement will throw if the element does not exist.
what's wrong with the syntax?
what can I use opposed to findelement?
I thinked to do two of those strings one if true run X string, and another one that if false, run Y string
nevermind I think that I've solved with try and else
thanks though
I thinked that I fixed, but I did not
