80mm slim fan recommendations?
arjones67
Go to solution Solved by Zagna,
Noiseblocker has worked quite well.
Anybody have a recommendation for an 80mm slim pwm fan?  I need one for a small form factor build in the Hyte (iBuyPower) revolt 3 case. I usually buy noctua, corsair, or arctic, but they don't make an 80mm slim.
I have this fan in my HTPC. It's not, like, incredible, but it also isn't loud and it's PWM.
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | a 10G NIC (pending) | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
Proxmox Server (Veda): Ryzen 7 3800XT | AsRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4× WD 10TB / 4× Seagate 14TB Exos / 8× WD 12TB (custom external SAS enclosure) / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-16i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives) | VMs: TrueNAS Scale; Ubuntu Server (PiHole/PiVPN/NGINX?); Windows 10 Pro; Ubuntu Server (Apache/MySQL)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
                           ┌─────────────── Office/Rack ────────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch 8-60W ─┬─ UniFi Switch Flex XG ═╦═ Veda (Proxmox Virtual Switch)
(500Mbps↑/500Mbps↓)                             UniFi CloudKey Gen2 (PoE) ─┴─ Veda (IPMI)           ╠═ Veda-NAS (HW Passthrough NIC)
╔═══════════════════════════════════════════════════════════════════════════════════════════════════╩═ Narrative (Asus USB 2.5G NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ──────────────────────────────────────────────────────┐
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═╦═ Byarlant
   (PoE)                 │                        ╠═ Narrative (Cable Matters USB-PD 2.5G Ethernet Dongle)
                         │                        ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Sony XR65A80K (Google TV)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Samsung 850EVO 250GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M | HooToo USB 3.0 PCIe Card | Osprey 230 Video Capture | NZXT H230 Case
TrueNAS Server (La Vie en Rose): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 1x Kingston 16GB SSD / Crucial MX500 500GB
║__________________║ hardware_____________________________________________________ ║
║ cpu ______________║ ryzen 9 5900x_________________________________________________ ║
║ GPU______________║ ASUS strix LC RX6800xt______________________________________ _║
║ motherboard_______ ║ asus crosshair formulla VIII______________________________________║
║ memory___________║ CMW32GX4M2Z3600C18 ______________________________________║
║ SSD______________║ Samsung 980 PRO 1TB_________________________________________ ║
║ PSU______________║ Corsair RM850x 850W _______________________ __________________║
║ CPU cooler _______ ║ Be Quiet be quiet! PURE LOOP 360mm ____________________________║
║ Case_____________ ║ Thermaltake Core X71 __________________________________________║
║ HDD_____________ ║ 2TB and 6TB HDD ____________________________________________║
║ Front IO__________   ║ LG blu-ray drive & 3.5" card reader, [trough a 5.25 to 3.5 bay]__________║
║ OS_______________ ║ Windows 10 PRO______________________________________________║
You have here 61  fans that are 80mm or 92mm, with less than 25mm thickness : https://www.digikey.com/short/24q5fr8q
You can filter to see only those with PWM control but the thing is most fans don't come with the header, they come with loose wires. You can  cut the connector (plus a short length of wires) from another fan and then solder the wires (or tie them and insulate them with electrical tape)
For example, Noiseblocker suggested above is max 2500 rpm , 26dbA and 14-52 m3/h or 0.233-0.866 m3/ min
You have 15 mm thick fans:
Sanyo Denki 80mm x 15mm thick , 2000 rpm max, 21 dbA and and 0.563m³/min (2 wire) : 109P0812M702 Sanyo Denki America Inc. | Fans, Thermal Management | DigiKey
NMB Tech 80mm L x 80mm H Ball 28.2 CFM (0.790m³/min) 2 Wire Leads 30dbA 2600rpm (2 wire) : 3106KL-04W-B40-B00 NMB Technologies Corporation | Fans, Thermal Management | DigiKey
Delta 80mm L x 80mm H Ball 28.3 CFM (0.792m³/min) 2 Wire Leads 30.5 dbA , 2700rpm (2 wire) : AFB0812MB Delta Electronics | Fans, Thermal Management | DigiKey
20mm thick fans:
Sanyo Denki 80mm L x 80mm H 20.00mm 23.7 CFM (0.664m³/min), 25dbA, 2300 rpm (3 wire) : 109P0812M601 Sanyo Denki America Inc. | Fans, Thermal Management | DigiKey
Sanyo Denki 80mm L x 80mm H Ball 29.7 CFM (0.832m³/min) 4 Wire Leads 26.5 dbA , 2900 rpm (4 wire) : 9GA0812P6M001 Sanyo Denki America Inc. | Fans, Thermal Management | DigiKey
... and there's more options, but they'll have higher dbA and higher rpm ... if you're never gonna run them at 100% they could be better than these lower noise at max rpm I linked above.
Thanks everybody.  I'm going to give the Noiseblocker a try.
  • 5 months later...
I know this is an old thread but I wanted to offer a recommendation. I managed to fit two of these ( https://a.co/d/cLlgPYL ) and thought I’d share. It takes some creative finagling and you can only use one screw on each fan, but they’re in and they work great. Used a Noctua pwm splitter for the CHA_FAN header on my Asus Strix B550i
