To start here is my system
Cpu - 5800x
Gpu - EVGA 3080 FTW
Case - Lian Li O-11 dynamic
CPU cooler - Lian li 360 AIO - top mounted
6 intake fans, 3 exhaust fans
So when I first built my computer at the start of last year, I had set everything up, and was monitoring temperatures closely, and the CPU was around 72-75c while running cinnebench. Which was great!
Fast forward to yesterday, while playing Hunt: Showdown I can hear my PC being a bit louder then i expected. I open up Ryzen master and I see my CPU sitting at 95c!!!!!
I freaked out shut down my computer, was looking at settings and everything was stock. Never OC'ed. and cleared my CMOS just to be safe. Adjusted fan curves and CPU pump curves to be a bit more aggressive. reapplied thermal paste and made sure that was all good. and just ran the game again...
Same thing...
So I undervolted it to 1.2v and have the speed set to 4.0 and while gaming its still getting to around 85c.
While sitting here typing this out with nothing else open, im sitting at 48c
is my cooler dying?
What am I missing here?
https://linustechtips.com/topic/1427266-5800x-temp-problems-help/
I don't suggest manual undervolting with Zen3 but that's besides the point.
Is the pump RPM OK?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
I would share a screenshot of Ryzen Master in Advanced Mode when the system is at idle.
A CMOS reset couldn't hurt as well.
The AIO may just be clogged, can you feel a temperature difference between the tubes? That method isn't really that great of a way to tell anything but its something. Might as well reseat it with new paste just to be sure.
From a spot of googling, looks like high CPU usage for Cryengine games is normal, and Hunt is known for being very CPU intensive. Seeing the temps people are claiming, I assume it's using AVX instructions on top of that.
1 minute ago, GuiltySpark_ said:
Is the pump RPM OK?
^^^ Your pump should be going 100% at those temps.
2 minutes ago, Cfischer6797 said:
Per the Bios its working just fine, but even in the BIOS its sitting at 40c,
Most AIOs have a utility you can run that lets you see and set fan and pump curves, see what it's running under load + how the coolant temps are.
AMD does say the max operating temp is 90C for the 5800X, so you definitely don't want to be running 95C regularly, I do doubt it'll kill the chip quickly though.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
When running cinnebench my temps shot up to 105c, and didnt even thermal throttle after only 15 seconds.
I already cleared CMOS before undervolting. and that didnt help. Thats why i ended up undervolting
CMOS has already been cleared,
New paste has been changed out.
And I can feel a difference in the tubes temps
If it's at all like a lotta intel boards, your board may disable a bunch of limits by default for better performance.
From what AMD has said on the matter, these chips are designed to hop up to 90C when they need to (allows them to pursue a longer boost time). Getting higher than that is definitely not intended, you probably have an issue with your AIO. Either mounting (it's not pulling heat out of the CPU), or the cooler itself (the radiator isn't pulling heat out of the cooler). AIO failures are usually pump related, I don't think I've seen reports of them clogging or anything, just the pumps failing. Thus the insistence on checking the pump rpm under load, you can also take a standard screwdriver, place the point against the CPU block, and put the handle on the bone just in front of your ear. Same concept as bone conduction headphones, it'll let you hear/feel the vibration from the pump spinning. If you don't then the pump is dead.
EDIT:
Yikes yeah that's a clog or pump failure, coolant temp should be basically the same throughout the whole loop assuming proper flow.
Mouse: EVGA X17
Something is off, I'd be curious if my pump is running at maximum potential. I use an EK 360 and it runs at full speed (2600RPM) at all times. I noticed you're also using a custom profile in Ryzen Master? You may want to revert all that to defaults using the reset button in the bottom left.
Idle with a -18 all core undervolt using the curve optimizer.
EDIT:
 Wouldn't one tube have hot water heading to the radiator from the block, and the other tube have cooled down water heading to the block?
This is the update after resetting, the custom profile was the undervolt
The coolant temp should equalize pretty quickly as it runs around the loop, constantly.  It shouldn't stop and pick up a bunch of heat in one spot, that means your pump has stopped, which either means something isn't plugged in (if it's on the CPU fan header then your mobo would throw a CPU fan error on boot, if not then it probably won't say anything) or the pump is dead.
Mouse: EVGA X17
A pic of your cooling setup might help in pinpointing any trouble spots. My 5900X ranges 42C idle to 75C-86C full load, PBO dependent -- air-cooled.
Edited by An0maly_76
Revised, more info
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
So it has to be working to a degree, I shut down my computer, unplugged the pump and temps skyrocketed so fast in the BIOS. So it has to be working somewhat
What is your room temperature?
This might be another case of gunk build-up inside the liquid lines in the AIO. Causing blocked or restricted liquid flow. Resulting to cpu high temperatures.
I suggest for you to stop benchmarking it while you are having these cooling issues figured-out. Your idle temps can already tell you if you have cooling issues.
I suggest for you to just get an air-cooler for your cpu instead. There are many options, I can help you out with.
Room temp is 72F
That case honestly doesn't appear well-suited for cooling. And that's probably a lot of your problem. It can't cool if there's nowhere for the heat to go.
My setup -
Corsair 4000X case - includes three SP120 fans
Added three LL120 fans (wasn't aware these didn't match the included fans, but they work)
Corsair iCUE Commander Core XT (two thermal probes in CPU cooler)
Scythe Mugen 5 Black Edition
Custom fan curve -- 50-75 percent 30C-70C - 85%-90% above 70. Never tops 76C without PBO, 86C with PBO.
Revised
The key point to not lose sight of here is this is a new problem that did not exist before. The current setup was perfectly adequate and working well so any suggestions to physically change anything would be losing sight of the problem.
I know we've mentioned it a few times but I don't know if you've fully answered it. Have you verified the pump RPM? The actual number. Lian Li doesn't actually seem to publish the RPM range on their site but some googling says it should be run in the 3000RPM range.
I would try reorienting the cooler, have it work in a different possition, might help clear the partial blockage.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Per Open hardware monitor it as at 1500 RPM right now
Case has plenty of airflow, it's set up for AIOs/Custom loops over air coolers, thus why the intakes are on the side and not the front. It just needs to pull fresh air into the case, the AIO fans will push it out. I would reccomend using the AIO as an intake and the side as an exhaust to maximize fresh air to the radiator though, with fans on the bottom to pull fresh air into the GPU it should be a good setup, but same concept as what OP already has, just flipped.
^^^ Assuming it's an Asetek AIO (almost all of them are due to Asetek having nearly all the patents), it should run about the same as any other AIO.
EDIT to avoid double post:
If you have the ability to set it to max rpm, do so and see if there's any difference in temps.
Mouse: EVGA X17
6 minutes ago, Cfischer6797 said:
Room temp is 72F
Your room is cold enough. That rules it out.
I suggest for you to change your AIO already. The Noctua's NH-U12A is a good option for you. Or an NH-D15, if your RAM allows clearance for double fan.
I have an 11700K overclocked (41%) in a room at 86F(30c) temp and it barely hit 65c on gaming. Idle is at 39-40c. Cinebench23.2 only reaches 85c on multi-core overclocked at 41%(~5100mhz) in same room temp 30c.
That wouldnt explain why it use to max out at 75c a while ago, it has plenty of room for the air to escape, plus my GPU never hits above 65c full load. so that seems to show plenty of air flow throughout
