CPU cooler problem
If the stock ram is 1333 at 1.5 volt then you may be able to push it higher but you will usually need a raise in Voltage and loosen the timings. That often negates the ram speed increase. Once you get the new CPU cooler on. Try to OC in the bios and set FSB to 200 and only use the multiplier until you get more familiar with overclocking.
Unfortunately, some of the MSI boards dont have LLC, so OCing is going to be a pain.
well those are some cool tips about OC'ing. thank you. i will definetly try that after a get a new cooler. just for fun. because all i do at my pc is to watch linus videos and streams and play League of legends. and i would love that my pc wouldnt sound like a jet plane when i watch a youtube video. you are probably right about the fan being voltage controlled because when i set the cpu_fan profile in control center it shows the fan slowing down acording to temperature but the speed readout is still 2130 rpms, so probably the cpu_fan controlls only PWM fans
