Hi all,
         I am looking at setting up a home studio and want a pc to record with. I have a budget of about £600 (uk) to buy every thing minus the keyboard, mouse and monitor. What will I need? I am off to uni soon so dont want a giant PC as i will not be buying another one until at least 2017. Would a good laptop be a good alternative? Thanks
I will be using Reaper
Edited by P-90
https://linustechtips.com/topic/142657-audio-workstation/
Hi all,
Your requirements will pretty much be decent CPU, more than average RAM wise (16 gigs probably), and a fast hard drive or two. Do you want a GPU at all? You don't really need one and that will keep the cost way down
Feel free to message me if you want to chat!
https://linustechtips.com/topic/142657-audio-workstation/#findComment-1904271
I was looking more for system specs, I will not really do any gaming, so probably wont need a gpu. How about the laptop idea?
https://linustechtips.com/topic/142657-audio-workstation/#findComment-1904285
Here's a simple build according to Reaper's recommended hardware setup.
You can add another 8 GB of ram and a storage HDD or get an i5 4570 and still stay within budget.
If you change your mind about gaming, just add a 750 Ti and your PC will be good enough for gaming.
I am sure any laptop with 8 GB ram and an i3 or an i5 will do a great job for you. Reaper is not a very resource intensive program and encoding audio will never push your processor very hard.
https://linustechtips.com/topic/142657-audio-workstation/#findComment-1904366
I'll get round to that in a bit. Just needed a bit more info :P If you're after one PC, to take to lectures as well, then the laptop is obviously the way to go. And seeing as you don't need a GPU that's that awesome, you've got a lot of options. Make your choice, laptop or desktop? (Personally, I'd swat towards the laptop if I didn't already have one.
https://linustechtips.com/topic/142657-audio-workstation/#findComment-1904371
I think a laptop would be best as I can take it to lectures and the like. Also, my budget needs to have a interface and a mic in it as well. So dont blow all £600 please.
https://linustechtips.com/topic/142657-audio-workstation/#findComment-1904391
oooooh. That's gonna be tough. Do you need headphones or monitors? Do you have a preference inputs wise or a type of mic (condenser/dynamic)
https://linustechtips.com/topic/142657-audio-workstation/#findComment-1904410
II am looking at starting with a dynamic (SM57 or E606?) and i do not need monitors/headphones
with an SM57 (I have one and love it BTW), and an interface from Behringer (*le gasp*) you're left with 450 quid for a laptop. Issss not looking so good. http://www.pcworld.co.uk/gbuk/laptops-netbooks/laptops/laptops/asus-x550ca-xx249h-15-6-laptop-21836943-pdt.html
something like that could be okay, I guess.
https://linustechtips.com/topic/142657-audio-workstation/#findComment-1904483
How much extra would I need to spend to get something that would definitely be good enough?
https://linustechtips.com/topic/142657-audio-workstation/#findComment-1904577
How heavy is the audio work you'll be doing? What's it for?
https://linustechtips.com/topic/142657-audio-workstation/#findComment-1906678
How about this? Seen the i7 and the price and got a bit interested...
http://www.pcworld.co.uk/gbuk/laptops-netbooks/laptops/laptops/acer-aspire-e1-572-15-6-laptop-21712969-pdt.html?sPageInfo=3_20&sSortInfo=price-desc
https://linustechtips.com/topic/142657-audio-workstation/#findComment-1910501
More RAM than the other, so that's good. If you can stretch the budget and are happy voiding warranties, throw an SSD in there. Perfect audio laptop sorted
https://linustechtips.com/topic/142657-audio-workstation/#findComment-1910587
Mostly simple stuff on reaper to start with, only a few tracks (Rhythm guitar, lead guitar, bass, drums and maybe vocals)
What are you planning/hoping to do later?
That i7 is worse than some mobile i5's.
https://linustechtips.com/topic/142657-audio-workstation/#findComment-1910755
