 Budget (including currency): around 6k USD
Country: Croatia
Games, programs or workloads that it will be used for: Not sure currently, but latest games, streaming, and video editing the streams and games. 1440p resolution
Other details https://pcpartpicker.com/list/97QNcb for the parts currently, would be buying it in about 2 months.
So Hello guys,
This is my first PC build, as well as that I would like to make a custom loop with hardline tubing. Now as i have no experience with PC building at all i understand its a tall order.
As stated i would like to make a custom loop, and honestly, i am researching it but, is there a good way to plan the loop? Also, i went with the O11 Dynamic from Lian Li as i like the design and also I quite fancy the EK-Quantum Reflection PC-O11D D5 PWM D-RGB - Plexi from EK (https://www.ekwb.com/shop/ek-quantum-reflection-pc-o11d-d5-pwm-d-rgb-plexi).
As well as going with planning the loop, I don't really know how to plan for all the tubing, fittings, and so on. Now because of Croatian tax and prices, this pc without any cooling is about 4k USD. I am looking at amazon in Germany to see as they may have better prices. But worst-case scenario i have about 2k for cooling and upgrades from the current plan.  For compatibility the other gpu options are:
GeForce RTX3080 GamingPro, 12GB GDDR6X, LHR
MSI GeForce RTX3080 Suprim X, 10GB GDDR6X, LHR
MSI GeForce RTX3080 Gaming Z Trio, 12GB GDDR6X, LHR
Gigabyte GeForce RTX3080 Gaming OC, 10GB GDDR6X, LHR
Please let me know if there is anything i missed or if you have any ideas,
For the monitor i was planning to go with the Alienware 38" AW3821DW, but if anyone has any better options please do recommend me something, I would like 2 monitors at least.
Thank you.
https://linustechtips.com/topic/1426538-my-first-pc-build/
29 minutes ago, Jeppes said:
Id wait till 4000-series comes out and closed loop only makes sense with highest end parts. 3080 is easily air-cooled.
Also someone who has never built a pc would probably have a lot of trouble with doing a custom loop. Make sure and wait and you can get a GPU that is most likely a lot better than a 3080 for cheaper.
  • CPU
    i7 9700k
  • Motherboard
    MSI MPG Z390 GAMING EDGE AC ATX LGA1151 Motherboard
  • RAM
    2x - G.Skill Trident Z 16 GB (2 x 8 GB) DDR4-4000 CL19 Memory
  • GPU
    MSI GeForce RTX 3070 8 GB VENTUS 3X OC Video Card
  • Case
    NZXT H710i
  • Storage
    Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive, Inland 240 GB 2.5" Solid State Drive
  • PSU
    Corsair RMx 750 W 80+ Gold Certified Fully Modular ATX Power Supply
  • Display(s)
    Asus TUF Gaming VG279QM 27.0" 1920x1080 280 Hz Monitor, Asus VG278QR 27.0" 1920x1080 165 Hz Monitor
  • Cooling
    NZXT Kraken Z73 73.11 CFM Liquid CPU Cooler, Also 10 NZXT Aer F fans,
    ACIDALIE M.2 Heatsink,SSD Cooler for Pcie NVMe or SATA M2 2280 SSD Cooling with Fan, for ssd
  • Keyboard
    Custom GMMK Pro with Kailh Creams and Inukuma Keycaps
  • Mouse
    SteelSeries Aerox 3 Bluetooth Wireless Optical Mouse
  • Sound
    Klipsch - Reference Series 5-1/4" 340-Watt Passive 2-Way Bookshelf Speakers, Denon AVC-3000, with (GDSTIME Rounter TV Box Cooling Fans 480mm) for music, SteelSeries Arctis Pro Wireless Headset for gaming
  • Operating System
    Windows 10 (unactivated)
  • Laptop
    Apple Macbook Air
  • Phone
    Apple iPhone 11 Pro (Mous Carbon Fiber Case)
https://linustechtips.com/topic/1426538-my-first-pc-build/#findComment-15364179
