Lan port adapter on phone
Solved by mariushm,
The specs say the s22 ultra can do :
Wi-Fi
Wi-Fi 802.11 a/b/g/n/ac/ax 2.4G+5GHz+6GHz, HE160, MIMO, 1024-QAM
Up to 2.4Gbps Download / Up to 2.4Gbps Upload
so in theory with the right router, you could do more than 1 gbps through wireless.
The USB port seems to be usb 3.1 gen1 or 5 gbps so in theory and usb 3 1gbps / 2.5 gbps network card should get close to 1 gbps.
How long can those high speeds be sustained will depend on the internal flash / extra sdxc card write speeds ,,, and for browsing or viewing videos from a share/nas the faster speeds don't matter.
